TTI system too long for Cuda
7DCUDA383A
60 Miles West of STL
Starting from the rear to the header flange too long . I have the TTI headers installed , those were easy , now putting the exhaust in from the rear first , I do have Flowmasters which are like half inch longer but with it all together it passes the header flange , I'm guessing since this system is made for E-body 70-74 and Challengers are longer , you have to cut the mid pipes about 5 inches or so , anyone with a Cuda have problems .
Yes, they make them slightly long to begin with to trim to fit and being that you have a Cuda you will have to cut more off than Challenger owners due to the 2" shorter wheel base.
I thought that's why they send an adapter , to move forward or backwards.
Cudas are shorter in the truck compartment too! About 2" narrower trunk lid. So 4" to 5" would get the flanges in the right place to bolt up to the headers looking at the above pictures.
I used the TTI 3" H-pipe exhaust from the factory manifolds back and had no issues with length. Just make sure the rear hangers are facing the right way otherwise they don't fit properly. You'll know when they are one the wrong way because they look like they forced in place.
Look good to you
Yes sir, looks nice and hanging straight. Don't snug the bolts through the rubber until you get the rest of your exhaust installed. I made the mistake of tightening them and had to remove the bolt and raise the rubber up one or two spots.
The thing I'm noticing is the right over the axle pipe seems to be about an inch closer to the front of the car , the gap between the axle and muffler is further than the drivers side , then the hangers are angled different , do you remember anything like that .
That looks good, there's plenty of clearance every where and those hangers aren't going to flex much!
Yes, I had some clearance issues also. I found that the exhaust pieces were not as engaged into the each exhaust piece. I went back and made sure each exhaust piece was pushed into each connection. It really made a difference with my 3" exhaust.
My hangers are not hanging exactly the same either.
I had the same thing. The TTI connections are extremely tight. I found that carefully tweaking them with an exhaust pipe expander made for an easier installation.
AutoZone’s free loan-a-tool program has a very nice kit to expand all sizes of pipe.
Once together, just use the stainless band clamps and you have ease of disassembly in the future.
