Seat Latch Wear
Cav73
Maryland
I just noticed that the latches for my Challenger's bucket seats do not actually latch.
I have had the seats out of the car for many years and after cleaning them and restoring the seat tracks, I am getting ready to put them back in the car.
The jaws of the clamping mechanism inside the upper seat appear to have carved notches in the metal catch bolted to the lower seat. I will attach a photo, but I noticed on other members' photos on seat latches that similar notches are visible.
Do we know what causes this? Is it possible to adjust the mechanism in the upper seat so the latch jaws are not clamped so tight they won't give enough to actually latch the catch? I tried to move the jaws with my finger but they don't budge. Maybe the spring pressure is too high to do that anyway. Pressing the release button on the side of the seat does not appear to move the jaws.
My seat stops are intact - is it possible to adjust them to allow the catch to work better?
My thought is to weld some new metal into the catches to avoid yet another part expense, but this might be pointless if the latch mechanism in the upper seat has to be replaced.
Is it absolutely necessary for the seat catches to work for safety reasons?
Thanks! One more feature to learn about...
My thought is that they are sticking from years of dirt etc and not being used. They may need to be cleaned and greased.
If the latches are not catching, when you hit the breaks the seat back could come forward and possibly push you forward, probably right when you don't want that to happen.
Yes, that would not be good. I took a look at the latch mechanism this afternoon. It looks like the jaws are wide open. Pressing the release button does not seem to do anything. I can hit it with some WD40; everything in there looks surprisingly clean. No obvious rust or crud, but it may be necessary to pull the latch out and clean it.
I don't even have the latches in my seatbacks and in 20 years of driving my Cuda that has never happened!
It has been so long since the seats were even in my car that I completely forgot they don't latch - if I ever noticed. I have the 1974 interior manual and in the seat section, there is a figure showing the latch mechanism exploded. But it does not discuss troubleshooting malfunctions.
It just describes repositioning the striker for a better hook to the latch.
I have to put the seats in as soon as I finish touch up paint and track assembly so I can get the car operational again. I do not like having something not working so eventually I will fix them.
It would be nice to know why they don't work. I can't see anything broken in the latch, but the jaws do not seem to close or open despite pressing the button.
Pictures make questions and answers so much easier.
And info more than my Challenger"
Year ?
The bucket seat backs on all of those seats, Whether on a B-body or E-body would bend easily.
Very common to see them look like they are laying way back.
The loops on the seat bottoms would be "shimmed" up with washers or spacer plates.
https://www.classicindustries.com/p...UagZSUfgCT7ls3jqASVYWoIzjaWqUkpxoCQ3QQAvD_BwE
OK, here are photos of my latch, passenger side seat. This seat has never been dissassembled.
The seats are out of a 1972 base 318 Challenger. The car they are going into is a 73.
I included a photo of a figure from the 1974 body service manual showing an exploded view of the latch.
As I recall from when the seats were in the 72 I had, they did lean back a bit and had no real adjustability. The stops are intact though.
Thanks!
Kidding, right ? The latch must engage the loop bracket. The bracket is made of a softer material. When the latch parts need service, the cheap bracket gets replaced as the latching mechanism will have no wear on it.
Moparleo, OK thanks! The loop bracket wearing out because the bar is softer makes sense. Based on the wear on the bar and the photos, can you tell what might be going on with the latches? What typically happens? The manual explains how to replace a latch, but not how to dismantle and service it - if that is even possible. I was unable to get the latch jaws to move at all, even pressing or levering on them with a screwdriver.
Unless someone is going to be riding in the back seat, why worry about it? It's only an added safety feature for being in a crash, so, unrestrained passengers in the rear don't crush you against the steering wheel. None of the mid 60's and older cars had them, and it wouldn't (and doesn't) stop me from driving one.
Thanks everyone. I just wanted to know what I am in for down the road; fixing the latches has to "take a back seat" to getting the rest of the interior done and getting the car running again and registered at long last. Rebuilding my dash and installing the carpet took forever!
I installed the seats last week. And to my amazement, the latches work now. Barely, given the wear on the loops, but they actually work.
