SOLD 1968 Cast 340 engine
Matt68
New Jersey
Don’t know if there is any interest in this engine as it came out of a 1969 Dodge Dart. It wouldn’t be correct for any Ebody and yes, it is posted in for Abodiesonly. If there is interest, I will post all the info on the engine. Asking $1,400. Located in North NJ.
No internals ? Just block, pan and bare heads ?
@moparleo main caps, crank, cam, oil pan, pump, pick up, windage tray, new water pump, timing cover, correct valve covers, correct intake, correct AVS carb, stock distributor, incorrect “J” heads, but I believe they are the larger intake/exhaust. New air cleaner. Std. Bore, no gouges or scrapes, probably clean up at .020 over.
I got a buddy that drag races from North East PA that may be interested. I'll let ya know in an hour or so.
PM sent
