SOLD 1970 Mopar Kelsey-Hayes Disc Brake Setup – OEM (Rebuildable)
Desert 70 Cuda
CA
Selling a set of original single-piston Kelsey-Hayes pin-type “wide mouth” calipers, casting # KH 80012 – correct for 1970 only applications with the larger pad clearance. $750 OBO takes it home!
  • Calipers will need rebuilding, but castings are in very clean condition
  • Factory casting dates are clearly visible and include the year
    • 085 0 3
    • 112 0 2
Included:
  • 11" rotors with original studs
    • Correct LH (left-hand) thread studs on driver side
    • RH studs on passenger side
    • Rotor Thickness: Left .962 and Right .991 inches.
  • Set of 12 LH thread lug nuts
  • Brake dust shields with mounting bolts
  • Two wheel grease caps
This is a solid, original setup that’s getting harder to find, especially with clean castings and correct hardware. Great candidate for a proper rebuild/restoration. Item is located Santa Clarita, CA
