FOR SALE 1971 Chevy Nova stroker
44070dart
buffalo
383/350/3:55 ..Very good.. Driver quality Nova.. SS emblems. Has a 383 with Vortec heads with Trick Flow bee hive springs, COMP Cam 268/280, .477/.480, with Comp double roller timing chain. COMP Cam Magnum steel roller tip rockers. RPM Edelbrock air gap intake, 750 Demon carb with Fragola pro stock fuel line. Summit HEI distributor with Ultra 40 wire set and PerTronix 600 digital rev limiter and Flame thrower coil. Flowmaster 3" exhaust with X pipe. Yukon posi rear end, and axles. Turbo 350 with shift kit and B&M Hammer ratchet shifter, TCI 2800 stall 10 inch converter. Summit power disc brake conversion on the front, QA1 tubular lower control arms, and 1 1/4" QA1 sway bar. Mono rear springs changed to new multi leaf rear springs. Goodmark steel cowl hood, and radiator core support. New weather seal kit installed. New interior door panels front and rear. New bumpers, front seat cover and sill plates. New windshield. Nice 7 and 8 inch rally rims. Torrid red paint still in good condition, couple bubbles on very bottom on dog leg, been there for years. Drivers floor pan replaced, the rest in very good condition with solid trunk and rails. Dash pad cracked, will need tires after the season. Have a LOT of actual bills for this car. $17,000..Buffalo NY
