1971 Dodge Challenger Parts
chally71e
Oregon
Entire Suspension/Drivetrain for sale from 1971 Dodge Challenger RT.
Front:
Upper Control arms
Disc Brakes-knuckles, disc, pads, dust shields,bearings, flex lines, hard lines etc.
complete sway bar-mounting brackets and everything to completely install
Torsion bars, clips, boots
Shocks (2)
Strut rods
Tie rod end
Master cylinder/Booster
Proportioning valve
Front brake lines
Rear:
Sway Bar assembly -complete
Spring pack
shackles
Drum Brakes-completed with backing plates, drums and all internals
Shocks (2)
Will include all hardware that I can get.
Price $1500 plus freight.
Some of this stuff could use a rebuild/repair/replace. Going with an aftermarket setup and have no need for it.
Also have upper cowl panel, will have vin stamp cutout and some rust damage. Good for someone that wants an original to repair. Also have a trunk floor, same condition as above. Kframe/steering gear, no discernable damage.
Steering column/wheel. Could probably use a rebuild or restore.
chally71e
Oregon
Bump. West coast.
I'd prefer to sell as a set, but would consider parting out.
71droptop
Lower Hudson Valley
Do you have rear tail light bezel. Even 1 side would be great. I need the reflector between the brake lights.
the 1 closest to the Challenger script in the center.
Thanks in Advance
