SOLD 1971 Dodge Challenger
Deepsubject
1971 dodge challenger it has a 383 motor it has been freshened up , with 413 wedge heads , new 484 lift cam lifters dubble roller time chain, hooker long tube headers, holly 4bbl carb & alum intake msd 6al spark box, mallory coil,triple pass racing cooler with dubble electric fans , & raceing tranz cooler with remote tranz filter, mark Dudley performance build 727 transmission with driveshaft loop , 8 3/4 rear end 3.91 pos gears all new brakes front disk & big back drums, lines, master cyl , dis block and all as well , new coil over shocks and track bars, sub frame connectors, new front and rear sway bars, new gas tank and lines and new flip top gasdoor , factory rims have been sa ndblaster a powder coated, new floor pan , new carpet, headliner, dash top, seats have been recovered front buckets and back bench seat new retro belts, factory console & slap stick snifter and recovered factory tuff wheel, new am / fm / sd / radio with power ant , new windsheld and new back glass vent shade,
the needs front door panels inside .
and finish installing aftermarket sport gadges .
both rear qtrs but i have both new full qts .
paint , i have a gal of ppg Factory B-5 Blue paint.
front and rear t/a spoilers need to be mounted .
and i have new R/T logos, black R/T side stripes and R/T side scoops .
NOTE : TRUNK PANS ARE GOOD !!! FLOOR PANS ARE GOOD !!!!
IT WAS A FACTORY 318 motor 904tranz , 276 gear rear end .... I HAVE THE BUILD SHEET ..
TITLE IS GOOD & IN MY NAME ...
NO BULL CRAPERS !!! NO MEMORY LANERS !!!! PLEASE DONT CALL ME AFTER 9PM THANKS !!
336 344 Five zero one seven .
Deepsubject
The casting number on head 518 ! so I'm I wrong that those was used on the the 413 ??
They are closed chamber!
DetMatt1
Metro Detroit
They’re 516 heads and are closed chamber but not max wedge. They have the smaller valves.
challenger6pak
There are smaller ports on non max wedge heads. The max wedge head ports are so large that the intake manifold wouldn't seal to them.
Deepsubject
This is why I don't like Most Mopar folks they get a orgasm just trying to prove folks wrong ! The heads was pulled from 413 ! I know that for a fact !
