FOR SALE 1972 Plymouth Barracuda 340/A904 3-speed/3:23 factory rear end
SRKlegin
Roy, UT
Good morning,
I am looking to sell my car which I have worked on very intensely for about 5 years now. I invested a lot of time and money at this car and truly love it. This is a hard choice. This not concourse, but mild resto-mod vehicle. I recommend visits to see the car for inquiries. Bids start at 52k. Sorry forgot to add price, members.
1st Owner: Oregon
2nd Owner: Oklahoma
3rd Owner: Me, UTAH
Body/Frame Mileage: 115k / BH23G dash plate intact
Engine bay Tags missing since Oregon...tried to locate first owner.
-- 2nd owner didn't bother to ask about them at his purchase date, or check for a bill of sale...etc (why?) LOL
Engine and powertrain
-- 1973 340LA (Complete rebuild) less than 200 miles on build.
-- Cylinder Bores have been sleeved all pistons at nominal diameter
-- Compression checks 150 to 200
-- Stock Heads 0.202 / 0.188
-- I.6 Roller Rocker arms
-- Comp Cam 20-810-9
-- Gross Valve Lift: Intake 0.535- Exhaust: .531
-- Duration: .050 Intake: 0.218 Exhaust: 224
-- Lobe Lift: .357 / .354
- Steel Crank
- A904-3-Speed column shift / TF2 Shift Kit (Less than 200 miles on rebuild)
-- 1800 stall convertor
Doug Thorley Headers
3" X-Pipe system
Summit Distributor and Electronic Ignition Module update
Taylor 8mm Spark Plug Wires
Complete Ignition harness /starter relay harness and solenoid replaced
Battery Tray replaced
Edelbrock AVS 2 650cfm with jet tune up kit (new)
-- Edelbrock High-performance fuel pump / braided hose fuel delivery system.
Rear End
Validated as 3:23: no maintenance done to date since purchase...nothing wrong from what I can see and hear operation is great
Suspension:
Front: Hotchkis-complete build / Front and Rear Sway Bar Entire system installed by Hotchkis certified mechanic and dealer
Rear: RIDETEC coil over suspension (reworked by certified Hotchkis repair facility: everything has been corrected from 2nd owner installation)
-- Both front and rear suspension is adjustable to suit driving needs. Goes without saying: Make sure you use a reputable suspension facility to do the changes.
Wildwood 4 Piston Braking system (partially installed by 2nd owner)
-- System checked/repaired and booster Installed by Braking system certified mechanic.
17x8 (Front) 17x9 (Rear) Year One Rallye rims with Michelin Radials
Body
Paint: 5-years Minor flaws (4): (See below)
- Drivers side upper quarter clear coat burn-through
-- Paint Flaws hood leading edge / Drivers side edge towards cowling.
Vinyl Top 5-years. Roof was sanded and 3-coats of high-build primer applied.
All new glass (Classic Industries)
Chrome Drip rails windshield, mirrors (all replaced)
All weather strips/bump pads, (replaced engine bay, body and trunk).
Original seats (50 years old) Minor wear driver's side.
Dakota Digital Rallye Gauge Cluster (Original Non-Rallye Gauge Cluster in box)
-- New fuel sending unit in tank. Not calibrated to gauge cluster as of today's date
Original Radio is in box...needs rebuilding...has pioneer/Rockford speakers
All interior molding (original) all fasteners have been replaced with interior body screw kit
Headliner and bows (Replaced)
Dome light / Rear View Mirror (replaced)
Door/window crank and handle hardware (original)
Passenger Door panels (5-years old)
Door sill Kick Plates (new)
Headlight bezels / taillight bezels (5-years old)
Whole interior has been "Fat-Mat"
Original Dash Pad (1 minor defect previous repair)
Original Wheel Well Trim molding
New front bumper
Grille; Original turn signal bezels (5-years old)
Rear bumper (original)
Body panels, fenders cowling etc. (Verified Factory original stamps)
Floor, trunk and roof. zero rust noted when started. POR 15 applied.
Minor repair to Driver's side lower quarter. (Appears and taps sound.)
Fat-Mat Short-pile carpet has been applied in trunk area to reduce noise
I also updated the hood to twin scoop hood out of Arizona and have the original hood which is in great condition here.
-- Barracuda 340 badging not an option since this was a 318 Car.
Good morning,
I am looking to sell my car which I have worked on very intensely for about 5 years now. I am within 4-years of retirement and am trying to get ready for retirement. I invested a lot of time and money at this car and truly love it. This is a hard choice. I have tons of pics of the build on my phone and will communicate with serious inquiries. This not concourse, but mild resto-mod vehicle. I recommend visits to see the car for inquiries. My original post only allowed 10 images so this is a continuation. Thanks for looking.
