SOLD 1973 Dodge Challenger Ralley - Matching Numbers.
Blackcatstrat
Connecticut
Hello all, pain full as it is I'm looking to sell my project car.
1973 Dodge Challenger with Ralley package.
Matching numbers car with original millage.
340 cid with 4bbl carb
A833 4 speed manual transmission with pistol grip shift.
Factory 355 Sure Grip possi rear differential.
Rally cluster with tach and 150 mph speedo.
Go Wing
71k
The wife wanted another old farm house so the project list has changed.
I would rather pass it along then let it sit in the garage and rot away.
The car is in typical condition for the year and will require the usual work
for restoration. Front floor boards, trunk pan, deck lid etc..
I drove the car for a while but striped it down to a rolling chassis to begin restoration.
I have all the original parts that will be needed to reassemble after the body and chassis
work is complete.
I was never reissued a title when I registered the car as its not required by CT law.
They no longer issue or re-issue titles for cars older than 1981.
Check with your local DMV as you may be able to get a title from your state after a vin verification.
$7500.00
INFO:
No build sheet.
VIN - JH23H3B257238
Engine Casting - 2780930 - 3B257238
Transmission Casting - A3 C99129 H 99539 - 3B257238 PR5864067 0934
Fender Tag:
N85 R11 V6X EN2
G36 J54 M08 M21 N41 N42
V1X U A57 B41 C16 C56
GK6 A6X9 000 B24 151520
E55 D21 JH23 H3B 257238
JH23:
Dodge Challenger
High
2 Door Hardtop
H3B: 340 240HP(net) 1-4BBL 8 CYL
1973
Dodge Main, Hamtramck, MI, USA
257238: Sequence number
E55: 340 cid 4 barrel V8 275hp
D21: 4 Speed Manual Transmission
GK6: Bronze Poly Exterior Color
A6X9: Trim - Basic, Vinyl Bucket Seats, Black
000: Full Door Panels
B24: Build Date: November 24
151520: Order number
V1X: Full Vinyl Top, Black
U: USA Specifications
A57: 72-74 Rallye Package
B41: Front Disc Brakes w/Standard 10in RR Drum
C16: Console w/Woodgrain Panel
C56: Bucket Seats
G36: OS Dual Racing Mirrors
J54: Sport Hood
M08: Simulated Louvers
M21: Roof drip rail moldings
N41: Dual Exhaust
N42: Chrome Exhaust Tips
N85: Tachometer
R11: Radio Solid State AM (2 Watts)
V6X: Longitudinal Stripes, Black
EN2: End of Sales Codes
Blackcatstrat
Connecticut
I'll work on that, won't be until tomorrow more then likely. I'll need to pull the car out of the garage again and its raining like a big dog up here.
The trunk actually isn't too bad, couple dime size holes but solid other wise.
Deck lid same deal, I was just going to have it leaded rather than replacing it.
Front floors not much to see, someone welded in some patches so you really cant see much, solid but looks like hell.
Small patch on passenger side, larger on drivers side doesn't extend under pedal area.
Dime size hole in passenger area in front of door (side firewall panel?).
Dime size rough spot drivers side rocker.
Couple small holes in firewall around brake booster, pencil eraser size
Drivers side front inner fender battery box area, maybe could be fixed but for the price of a new one not sure if it's worth it.
Seems like more small isolated areas rather than any major rot.
Overall I have seen much worse, it's a real good platform to start from.
Take care.
Blackcatstrat
Connecticut
After looking the car over and doing some research on what similar cars are going for I have decided to drop the price down to $6500.00.
I took some more pictures of all the areas that I know of that will need work. I was disappointed to see that just from sitting that things were a little worse than when I last looked which was about 7-8 years ago.
If I were going to keep it I would just put a complete floor pan in it and take the cowl off and put either a new one on or something salvaged off another car. Whats there could be fixed but not sure if its worth the time. Just my thoughts..
Still not to bad....
Is what it is I guess.
PICT2143.jpgPICT2144.jpgPICT2145.jpgPICT2146.jpgPICT2147.jpgPICT2148.jpgPICT2149.jpgPICT2150.jpgPICT2151.jpgPICT2152.jpgPICT2153.jpgPICT2154.jpgPICT2155.jpgPICT2156.jpgPICT2157.jpgPICT2158.jpgPICT2159.jpg
challenger6pak
I had a 74 Rallye that was the same Bronze. It is a great looking color with the black stripes.
pete9857
yes, thats a bronze metallic g6k, my cuda will be that color, GLWS
Blackcatstrat
Connecticut
Been busy over the past few months and spent a fair amount of time and money on the car and have it just about all back together and running again. Will post some picts and maybe a vid over the next couple of weeks. Just waiting for some exhaust parts to come in which should be here tomorrow. Not likely I'll make a dime off it when/if I sell it but its good to hear it run again.
Jer
quapman
Awesome. I think about your car from time to time, but am still financially challenged. Wanna buy a house in central NC? LOL
Blackcatstrat
Connecticut
Got to be better than Connecticut....working class people get the screw put to us. Don't get me started! LOL. NC is real nice I used to go down to Jacksonville a lot for work. Real nice people down there...
Anyway here are a few more updated picts of the car. I did get a video of it running but I am still dry fitting the exhaust and it was banging around down there. I put all new front brake lines on it, new McLoud clutch, new headers and exhaust,ignition module, belts hose's plugs etc..new fancy air cleaner. To much to remember. I'm scared to look at all the Jegs and Napa receipts lol..
Also got all the electrical "issues" fixed as well.
Overall its much better off than it was when I was driving it.
Jer
Blackcatstrat
Connecticut
New starter (not a mini starter)
New battery tray with proper brackets and hold down.
Tires are new but nothing fancy, just got tired of having to put air in the old ones every 2 days...
New Bosch gauge set
New master cylinder
New clutch fork
Engine wiring harness's
Newer Holly 600 carb
All new hoses including vacuum lines etc..
I will put in a new carpet in before I re post it for sale.
I'm sure I am forgetting something (s)...
After the exhaust all thats left is the center console, carpet and remaining front body parts.
Jer
