travbstealthy
- Joined
- Oct 16, 2011
- Messages
- 23
- Reaction score
- 0
Looking to trade this car for a decent E-body Willing to trade up of course...this car is worth 14-15k here is a description...
1992 FIJI BLUE RT/TT
Long Block
-Forged crank
-Pauter rods
-Ray
Pampena pistons & rings
-ARP main bearing stud kit
-GT-Pro stage 3
port & polished heads
-99 lifters
-ARP head bolts
-Port matched
lower intake
-Polished valve covers and intake manifold
-Fully balanced
rotating assembly
Boost & Exhaust
-IPS 19T-HL turbos
-Ceramic
coated exhaust manifolds
-Huge GT-Pro FMIC kit
-Greddy type-s
BOV
-Stainless Tanabe 3" exhaust, dual outlet (no cats)
Fuel
-Denso
720 injectors
-Dual in-tank Walbro 255 pumps (hotwired)
-Braded stainless
-6 feed & -8 return fuel lines
-Aeromotive fuel pressure regulator &
gauge
-GT-Pro dual feed fuel rails
-Devil's Own stage 2 methanol injection
w/2.5 gal sump tank
Drivetrain
-Polyurethane motor mounts
-Man-Trans 25 spline remanufactured tranny and t-case
-GT-Pro t-case
brace
-ACPT one piece carbon fiber driveline
-3SX CV shafts
-Spec stage
4+ clutch
-Short shifter
-Solid shift linkage
bearings
Electronics
-AEM EMS engine management
-AEM MAP
sensor
-AEM intake temp sensor
-Boost a spark ignition amplifier
-MSD
spark plug wires
-Greddy Profec B spec 2 boost controller
Suspension,
Brakes, Wheels & Tires
-New oem ECS struts
-Tein S-Tech
springs
-3SX adjustable upper control arms
-3SX rear steer
delete
-Stillen cross drilled rotors front & rear
-Stillen brake pads
front & rear
-Stillen braided stainless brake lines front &
rear
-BBS 18" 2 piece rims
-245/35R18 tires (80% plus
tread)
Audio/Video
-Pioneer DVD/NAV system
-Pioneer 6 disc DVD
changer
-Rockford Fosgate speakers front & rear
-Alpine 4 channel
power amp
-Viper paging alarm w/remote start
~2000 miles on a
fresh motor, turbos and drivetrain, the rest of the car has just under 81,000
miles. The motor was assembled by Larry McCoy at Automotion in Medford then
brought to certified AEM tuner John Reed at PSI in Portland Oregon. John is one
of the best & most respected AEM tuners around, if you've never heard of
John, google him. He dialed the car in with a very safe, conservative,
streetable tune making 464 uncorrected awhp @ 20psi. Turbos spool extremely
quickly to produce a VERY even powerband, it drives like a stock car until you
lay into it. The motor, fuel supply and drivetrain were built to handle big
power, larger turbos would easily put it at 600+ awhp.. The rest of the car is
in well above average shape as well, fresh paint about 6 years ago (high dollar
work). The interior is also in great shape, with the exception of a couple small
splits on the drivers seat. All power options work great, has the sunroof &
the A/C blows ice cold.
Long Block
-Forged crank
-Pauter rods
-Ray
-GT-Pro stage 3
-99 lifters
-ARP head bolts
-Port matched
lower intake
-Fully balanced
rotating assembly
Boost & Exhaust
-IPS 19T-HL turbos
-Ceramic
-Greddy type-s
BOV
Fuel
-Denso
720 injectors
-Braded stainless
gauge
w/2.5 gal sump tank
Drivetrain
-GT-Pro t-case
brace
-3SX CV shafts
-Spec stage
4+ clutch
-Short shifter
bearings
Electronics
-AEM MAP
sensor
-MSD
spark plug wires
Suspension,
-New oem ECS struts
-Tein S-Tech
springs
-3SX rear steer
delete
-Stillen brake pads
front & rear
rear
tread)
Audio/Video
-Pioneer 6 disc DVD
changer
-Alpine 4 channel
power amp
~2000 miles on a
