Dodgeguy62
- Joined
- Feb 27, 2016
- Messages
- 8
- Reaction score
- 0
Okay guys I have a question, I was driving my car to work the other day, and my car started to overcharge. I had my headlights on, and I first noticed a pop then my high-beams turned on. Checked all my gauges and it was overcharging, played with the dimmer switch and I couldn't get my high beams to turn off, got to work and parked it. Next morning on my way home, same problem, except when I parked it, and turned the headlights off, my high beams stay on. I used a multimeter to check voltage output and was at 18.5V under throttle. Bought a new voltage regulator and it still over charges. So that's one issue I need addressed and thoughts on. Next is the headlights, I unplugged the dimmer switch and the high beams still stay on. I played with it a bit and couldn't figure it out. I let my dad play with it a bit while I was at work and he tore the instrumental cluster out and he said he disconnected the plug to the headlight switch and they still stayed on. Any thoughts on where to begin? Thanks
