Front light harness problem
transam
OK Did some more probing. First I should say that I recently changed the front end lighting harness and also installed 4 new OEM side marker light housings with the attached pigtails. I was thinking a headlamp switch or the dash dimmer switch which are both original to the car and maybe why my running parking lights are not working. So I installed two new switches and I also removed the cigar lighter . I am now not blowing fuses but I still do noy have dash lights, side marker lights or parking lights. I do have headlights high and low. Brake lights and directionals and 4 way flashers all work? So now I am wondering about the brand new OEM side marker lights up front of maybe the new front lighting harness. Any thoughts?
after my car came back painted,my side marker lights and tail lights did not work. After a bit of probing realized my lights were not getting a ground.Used a 16 gauge green(i'm an electrician)wire to a screw that was connecting the body to the ground and all lights are working..Anyway just thinking you should chec your ground
Yup Exactly what mine were doing and needed a good ground.
