Flathead31coupe
In this picture, where does the spring go?Thanks.
Thanks that helps.. All the pictures I find the spring is missing.. I wonder if that spring is sold separatelyHere you can see the spring at the top of the gear shift control shaft.. Hope that helps.
Thanks again.I found the spring called a slap stick shifter , springThanks that helps.. All the pictures I find the spring is missing.. I wonder if that spring is sold separately
Jamie at Mega Parts sells them.. Probably a few other places too.Thanks that helps.. All the pictures I find the spring is missing.. I wonder if that spring is sold separately
You are welcome. I was looking when you posted you found it already..Thanks again.I found the spring called a slap stick shifter , spring
Thanks..Like @QuickBpBp posted, that spring is seriously wonky in its operation but it works!
View attachment 151205 View attachment 151206 View attachment 151207
