Getting to assembly my 440 and thought I had a 402 pan. Turns out I have a 971 and 933. Will the 971 work on Ebody? I have a skid plate on my k frame.
TIA
We get a lot of questions about oil pans. For most passenger car swaps the basic answer is: you need a low-profile, center-sump style oil pan, standard on most passenger cars. This means that if you are taking the donor engine from a truck, van, or motor home, you can't use the oil pan. Below...
Wow! That will be very helpful. When I get in the house I’ll actually compare the two pans because I know the 402 is used quite often. At first class it looks like the 971 should work.
Thanks Daves69
