don selleck
Noticing alot of pressure on the rear casters, ended up going another route, put together one of two gantry cranes today, pretty heavy duty to harbor
freight
yep cheap on amazon got one for each side just measure the length they are coming loose, been pretty rough on them, will use them for painting also then probably replace, and silicone the new one's in place unless I can clean them and get the paint off of themDon, I like those lighting strips you have on your lift. Is that an LED tape down type?
thanks, finished up the other gantry crane, went over the under for any more undercoating residual, taped off most of the holes. going to double secure going to wipe the rest of any oils I can find. need to cram some blankets etc. around wheel tub and go thru some more protection to slow down infiltration of the stuff I will be finding for years to come.Nice looking fish, look forward to seeing this progress. Good job!
right color too
blast off scheduled for friday morning.
. About 3 months ago a line blew off after some construction adjustment and it ran for 10 hrs. it got hot but changed the oil and seemed to be working fine, the added stress of the sand blaster did her in.tried to buy a new pump for it discontinued of course, was pretty good" assembled in USA" lasted for 10 years thoughI agree you have the best excuse and need to go buy a new air compressor!
That's crazy! At operating temperatures the pistons would be just about touching the cylinder walls! I sure hope the previous "rebuilder" at least used file fit rings! On the plus side, your machinist might be able to power hone it for some nice .020" over forged pistons!Talked to the machinist on my block today, come to find out the cylinders were bored out to .018 ??? over. pistons were .020 hmm, another slight issue. That outta add a few horse power
