AAR resto
don selleck
michigan usa
Yes that is pretty nice they make cheaper ones that don't last, had one and fell apart bought this one have had it for a few years now seems to be holding up well. I'll get a close up shot for the make on it.
mrmopar340
Shawsville Virginia
been busy today with other stuff too.
Picked up my 8 3/4 with 3.73 gears, balanced driveshaft.
got a call from Bob at Glenray radiator my new repro radiator ships tomorrow, should be here Saturday.
ordered my stroker kit form CNC motorsports along with my hughes solid roller cam. 10 weeks out for the custom cam grind ☹️
a quart of organizol shipped from 8774 paint.
canceled yearone order from 4 weeks ago for a front spring mount still no word on when it will be in. ordered it from Mancini today, will be here tomorrow. unbelievable.
inline tube front stainless flexible brake lines and fittings came today.
Billie touched up the back side of the gillrockers with black paint. argent silver on the face.
cleaned the grill and coated it with 303, looks like new 55 year old piece pics to come.
pulled the back casters off the car, waiting for a few touch ups on the rear end the brake component install on it then back on all fours.
contacted hughes convertor and filled out their tech sheet for a convertor match
I think that's it what a whirlwind today feels great getting closer on this sweethart.View attachment 144228View attachment 144229View attachment 144230View attachment 144231
heres some of the specs for the engine.
You're going to love that stroker. Make sure to clearance the bottom of the bores to clear the stroke of the rods.
WFHDANB426
CANADA
AAR Cuda is my favorite car and I wrote three Cuda songs that are on youtube if you want to check them out under my artist search name: WFHDANB426
The songs are AAR CUDA, 70 CUDA & 71 CUDA. Hopefully my songs inspire people to keep restoring and loving these Cuda's as much as I do, even though I don't have my Cuda's anymore and can't afford one now. Great project and I'm looking forward to seeing yours when it's done.
Don, I sure hope you're running aluminum cylinder heads with that 11:1 compression! Either that or race fuel!
Make sure once you get the short block built, you use model clay and check the valve clearance! .600" lift is quite a bit! I usually do this without the head gasket and the head bolts basically hand tight. That way the gasket will give you an additional .025" to .040" valve clearance. Also, you want a quench zone of between .040" to .060" ideally. That will really help with proper combustion!
don selleck
michigan usa
edelbrock performer heads 65cc 2.02/1.60 I plan on a little 110 to mix with some 93 if necessary. I love a pop corn machine. but not full race gas all the time
don selleck
michigan usa
talked to hughes torque convertors filled out the card for match up came up with a suggested 3500 stall, I was thinking 3200 but sounds more like the ballpark since I'm stepping up on it a bit. Ordered it should be here in a week.
While having a beer or 3, I was taking closer observation of the hood situation, and realized that a 1x2 steel tubing will fit in between the sides of the existing support structure on the hood, so I'm gonna cut out the factory angle and the face of the fiberglass that was installed in the hood to bolt the hood to the hood hinges out, eliminating the factory issue also and keep from adding more weight.
then reinstall a 1x2 tubing in lieu of the factory stuff drill and install some weld nuts at the desired area to bolt the hood to the hinges. thus eliminating all the dumb ****. I love Mopars.
don selleck
michigan usa
ordered some 5/16 weld nuts for the hood,
lubed up the leaf spring bushings, getting ready for install, laid out my shock mount plates, realized I have 2 left hand sides, ☹️.
ordered them a long time ago can't seem to find the receipt of course, sucks. thinking I got them from Mancini but not sure. checked all my online receipts found it nowhere, having trouble bringing up Mancini ones so I ordered a non original looking set from them being the oem ones are out of stock, bummer, left them a note to see if they can check and see if I ordered the other ones from them. Touched up the rear end, drive shaft and bump stop with some eastwood chassis paint. Seem to hold up well 2 part ceramic paint has a little soft finish kinda rubber, doesn't chip like regular paint, rocks dent it more than chip it off.
don selleck
michigan usa
Talked to my friend down the road, he has built multiple engines with success over the years. He was talking about getting the rotating assembly in and checking the clearances, so I think with his guidance I should be good. Another older friend Doug Barker lives up the road in Grass Lake, moved there from around the corner, big Mopar nut used to race Hemi's in the 70;s and 80's Barker brothers racing, he did quite well back in the day, hoping to have him stop in while the engine is going together too. can't get enough minds together when putting this together, thank you very much for all your input, appreciate it. And welcoming any more.
don selleck
michigan usa
had a broken mount on a headlight bezel cut a piece of thin steel, drilled 2 opposing holes and cut a tab to spring it into place with a bezel screw to keep it lined up then plastic epoxy.with the extra steel reinforcement
should hold.
don selleck
michigan usa
riding high in the back, pulled down with 300 lbs set it about 1 1/2 inches above the top of the tire gonna let it relax a bit too, its not over yet. 😁
don selleck
michigan usa
got the repro radiator from glen ray a few days ago threw it in the car to keep it safe. very nice, and one of the last ones from them, glad to get it.
