Olacmot
Has anyone wired an auxiliary fuse box in? I am going to put my low beams and high beams on relays, and wanted that to look cleaner than just having two relays hanging somewhere with in line fuses. I also replaced my gauges and don’t have the ammeter any more; the ammeter terminal wires have been spliced together behind the dash. I was planning on doing the ammeter bypass/charge wire off the alternator to the starter relay as well. Plus I have MSD Ignition that needs a fuse, a very wimpy amp for the rear speakers that needs a fuse, and I have an electric fan I want to use a relay for, so I thought this auxiliary fuse box might kill a few birds with one stone.
I plan on leaving the original fuse box in place, my thought was this would be a quick way to add new fused loads without me rewiring the entire car, and reduce load on the bulkhead connector. I have a Tru Mods relay and fuse box, unfortunately it doesn't have a main breaker, so I was going to use it with a positive and negative terminal block, the positive terminal block being fed from a fusible link off the alternator.. I was thinking about mounting it on the passenger side fender near the alternator, but I'm wondering if anyone has put them elsewhere that has worked out well? I've included a picture of the location and a rough diagram of my plan. The direction of the circuits on this diagram aren't necessarily accurate, I just put them where I had space on the picture for clarity. Such as the Battery and Charge wires to the bulkhead connector will most likely be run towards the firewall, not near the radiator. I hope that makes sense.
My rough plan is below. Looking for input if I'm overcomplicating this or missing anything. Or if this is a bad idea in general, stop me now!
- Mount new fuse/relay box, a - terminal block, and a + terminal block. Ground - terminal block to body, + terminal block will feed all fuses in new fuse box.
- Use a #10 fusible link off the alternator battery post, spliced to #6 wire, and terminate this wire on the new + terminal block
- Remove old alternator charging wire from alternator
- Splice old alternator charging wire and battery wire together (#16 and #18 at bulkhead connector), and land on 30A fuse off new fuse block.
- Run new #6 wire from + terminal block to starter relay post.
- Wire from Fuses to relays, and run new wires from relays to headlights...maybe splice into existing harness, but that would make wire lengths longer. Haven't decided.
Questions:
- Should I use a fusible link where the #6 wire from the + terminal block connects to starter relay? This circuit is protected by the alternator's potential by the fusible link between the alternator and + terminal block, but the wire has no protection from battery potential between battery and + terminal block.
- Can I use a fuse instead of a fusible link for the charging wire and battery wire? Factory used a fusible link... is there enough inrush current on lights and interior loads like the radio to need a fusible link? I could splice these two wires together after the factory fusible link if necessary.
I'm curious to know your thoughts, as lots of you have LOADS more experience than I do. Pun intended.
Thanks,
Tom
Questions:
Thanks,
Tom
