B to E body disc brake swap
Tirekickertoo
Upstate New York
Hello,
I have a 1971 Dodge Challenger that has front drum brakes. I have available a 1973 Dodge Charger (B-Body) that has front disk brakes. I want to swap out the front drum brakes and install the disc brakes/spindles etc. Any issues doing this? I don't believe there is but I want to double check on this forum. Years ago I read an article from Moparts that had charts on what suspension parts/brake parts interchange between B and E body based on the VIN#. Anyone have this chart or can send me the link? Your thoughts...
Thank you,
Tirekickertoo
Tirekickertoo
Upstate New York
Hi DrEamer,
Thanks for sending the link and video, enjoyed them both. A few years ago I needed disc brake caliper mounting brackets for 1973 Challenger disc brake spindles. At that time I was able to find a link on Moparts that identified what brake components were interchangeable between the B&E body cars based on the Vin# and I believe casting numbers stamped on the parts. I was successful in finding a junkyard 1974 Dodge Charger that had the caliper mounting brackets I needed. The fit perfectly. I'm not so sure now on the spindles? A lot of opinions and uncertainty regarding my original question wondering if 1973 Dodge Charger disc brake spindles will fit a 1971 Dodge Challenger? A lot of this discussion seems to be based around the 73 Charger spindles being too tall to fit on a 71 Challenger. Bump steer and premature ball joint wear / failure are a concern. Still searching for a definite answer.
Thanks for the help,
Tirekickertoo
The 73 B body has a completely different system , the K frame was isolated from the frame with rubber blocks , the spindles are taller , while it may work it is not the best swap , any of the FMJ spindles fit so Volare, 5th Ave etc , I have converted many cars using these parts with no issues
Robert Franke
Mineola, TX
Lol! Wish I would have had dr.emers link a year ago! I bought a clean 71 challenger and going thru it I found front disk brakes. First glance they looked factory. Chrysler markings ect..I ordered 71 parts...nothing fit! Eventually a good parts guy figured out I had 74 brakes on it! They work!
