Carb transmission rod clip
notacuda
Bonita Springs, FL / Stow, OH
Can anyone help me find a clip that goes on the end of the carb/transmission rod kick down lever. My car is a 71 Barracuda 340 , 727 transmission, all factory. My parts catalog shows p/n 2946640 b/c crank to carb rod. Any help would be appreciated!!
Tom
You might be able to find something in The "Help" parts at a good Auto Supply. They have a lot of little clips that you can get to work for you. The parts manual shows two different types so it's hard to figure which one you need.
Glad you found one, i had one available if you didn't
I want thank everyone for the help. Maybe you all can help me with a bigger problem. My throttle linkage does not line up with the carb. The set up on the top half of the 340 is a Edelbrock Air Gap intake with a Holly carb. I can't use an aftermarket throttle bracket because of the trans. kick down rod. See pic attached.
Correction on the Barracuda year, it's a 72.
