Changing head light on a 70 AAR
Lawrence Shaw
I feel kind of stupid asking this but can someone give me the steps to change the head light bulb in my car? It does not appear to be as straight forward as I thought.
budascuda
There are no bulbs, its old tech, the whole thing is a bulb! Like Sealed Beam.
Yes a lot of waste, this why they changed
Good luck.😇
Lawrence Shaw
Yep, I know that. So how do you remove the entire piece. In other brands there is a trim ring around the bulb. You remove the trim ring the bulb comes out for access to the socket.
budascuda
Sorry, I think if you remove the chrome bezel (in challengers) then you can get to the trim ring.
After removing the bezel there are 3 screws around the headlight , DO NOT remove them , just loosen them & twist the trim ring & the ring will come off the screws so none will get lost
