SOLD Comp Cam high performance NEW Valve Springs For Sale
340challconvert
Parsippany, NJ
Comp Cam high performance Valve Springs For Sale 901-16
The Comp Cams 901-16 is a set of 16 single outer valve springs with a 1.494" OD, featuring a 1.080" ID, 330 lbs./in rate, 105 lbs seat pressure at 1.650" height, and a 1.100" coil bind height, designed for around 0.490" max lift, often used with hydraulic flat tappet cams.
I was going to use on my 340 heads rebuild
The machine shop purchased springs for my heads so i am selling these
(These springs are slightly larger then the stock springs and do not use the factory spring cap)
Specs:
  • Type: Single Outer Spring with Damper
  • Quantity: Set of 16
  • Outer Diameter (OD): 1.494"
  • Inner Diameter (ID): 1.080"
  • Spring Rate: 330 lbs./in. (some sources say 353 lbs./in., but 330 is more common)
  • Installed Height: 1.650"
  • Seat Pressure (at 1.650"): 105 lbs.
  • Open Pressure (at 1.250"): Approx. 242 lbs. (at 1.250")
  • Coil Bind Height: 1.100"
  • Maximum Valve Lift: ~0.490"
  • Recommended Use: Hydraulic flat tappet camshafts, providing stability for higher RPMs
They are applicable to many Mopar and other brand applications
Purchased from Summit- current price $88.95
Will sell for $65.00 plus shipping from Parsippany, NJ 07054
