driveshaft needed
rs1
there is one on moparts looks like a good deal..
aussiemark
Perth Western Australia
Depending on the engine the length varies if you can't find the correct one you can find one that is too long and have it shortened and rebalanced but you can't extend one that is too short.
Turbostang7
I've had them extended before, it's more expensive because the basically change the whole tube out but it can be done
aussiemark
That is basically what I said, you can't have it extended they will just make a new shaft and if they are going this far why use any old parts you may as well go for a full new set up.
AUSTA
PERTH WA
Does anyone know where i could find a driveshaft for a 1970 challenger with a 4 speed trans and an 8 3/4 rear?
On the rear measure the distance across the outside of the flat where the uni fits in to see if you have a 7260 or a 7290 also counts the teeth on the output shaft of the gearbox if you have a yoke that fits the output shaft slide it on then move it back about 1 1/4 then measure the centre of the universal joint front to the centre of the rear uni to get the tail shaft length
js29
lee center ny 13363
don,t measure it with the wheels hanging!!! you want the weight of the car on the rear tires. other wise it will be to long and bottom out.
Cazbah362
I have one from a 1970 Barracuda with a 318 and 4-speed, should be exact what you need. I had it rebuilt, balanced and new u-joints - never ran. I would want $225 plus shipping, if you are interested, please pm me.
Mopars & Missiles
I also have one, from a '70 Challenger. I would have to measure length for you to verify it is correct for your car. PM me if you are interested.
aussiemark
Wouldn't the Barracuda shaft be shorter then the Challenger shaft considering the wheelbase is shorter?
Mopars & Missiles
According to MoparLeo's chart shown above in post #7, you are correct. Chart shows B shaft versus J shaft is 2" shorter on '72 models.
I have a '70 model FSM with that info, but don't intend to go look it up and waste time duplicating his post.
RUNCHARGER
I have an original 340, 4 speed Challenger driveshaft. It is complete and has the 7290 on one end and 7260 on the other. I live in Canada so I don't know where you would need it shipped.
Sheldon
topbanna70
Thank you for the reply sheldon, I live in virginia do you have an idea of how much you would want for the driveshaft?
RUNCHARGER
Yikes! Virginia is a long ways away, I live above Wa. state. I want $200 plus shipping for it and due to the length I would imagine shipping would be costly. I could probably ship it from Wa. but it would be a while before I could do it. Let me know if you don't find another one.
Sheldon
