Odin
Who do you guys like for making replacement Fender Tags? (A.G. Backeast, MMC Detroit, etc.)
Also, do I have to remove and replace the dash VIN tag if I replace the dash pad?
I bought a 71 Challenger a year ago. The dash pad is cracked like the Grand Canyon and the fender tag is missing. The dash VIN tag matches the numbers on the cowl and radiator mount and body. I also found the build sheet under the rear seat springs, which also matches all the numbers. There were some changes made by prior owner(s) including replacing the flat hood with an RT hood , swapping out the original 318 with a 440, and removing the vinyl roof. When compared to the build sheet, most or all of the other codes match items still on or in the car. I should receive my new steel-core dash pad from DashPad Pros soon so I am wondering what to do with the VIN or if I need to do anything at all. I also want to make replacement Fender Tags with the original codes to match the build sheet.
All input is valued, but please no comments about how replacement fender tags are counterfeit and similar. I will make them to match the build sheet so they should be exactly the same as what originally came on the car.
