Front Sway Bar Mounts
jeff stafford
Hello, looking for a pair of 73-74 front sway bar mounts or let me know where I can get a repop set.
What size sway bar? They come in different sizes.
Once you know the diameter it will be easier to find the bushings. I was able to find urethane bushings, with the right height, online.
jeff stafford
Adam, I'm sorry I didn't say I'm needing the mount brackets that will bolt to the K frame
Steve340
New Zealand
Classic Industries has some of what you need. I have seen the support brace and the U clamp set somewhere but cannot remember.
Are you trying to fit a sway bar to a car that never had one?
Have you got the tabs on the lower control arms?
jeff stafford
Correct, I am fitting a non bar car. Yes I just purchased a set of lowers with the tabs. All I need is the metal mount that bolts to the K frame. I Will have to make a set.
