glass scratches
Mike Rafone
Indiana
Whats your recommendations on addressing a side glass scratched from a worn window seal and windshield from a bad wiper?
I will admit it unnerves me to put a sanding disc on a drill and hitting it. It very well may be the thing to do it's just a little nervy to me.
A general rule I recall, is if the scratches are deep enough to feel with your fingernail, they are too deep to be polished out. Otherwise, a cloth-like polishing wheel is used with an appropriate polishing compound.
I believe you can fill a deep scratch and buff it out.
Call a glass company, they should be able to fix it.
If the scratch is light, then you should be able to buff it out
You can certainly fix or make less notable scratches than a crack!! Call a glass place in your nearest town (I say that because I live in the boondocks not in town)!
you can successfully remove even DA scratches with Glassweld G-Force Max.. Check it out at Glassweld.com under scratch removal. the kit is expensive $1000-$1500 but it does work. My 70 Cuda front and rear glass was scratched with DA scratches on the edges and corners. It takes a lot of time for deep scratches but it will get them out. on the rear i had 15+ scratches all over with most being deep enough to catch with fingernail and DA scratches on the corners and edges. i got 90-95% out and made the glass very usable for my restoration. I sent two side windows glass back to classic because of fitment issues and that was when i bit the bullet and got this kit. saved all the glass and now I'm working on saving my 66 Vette glass as well. There are some youtube videos on it as well you can check out. If anyone goes down this road, reach out and i will pass on the tricks i learned to save you some time.
I'd love to hear some success stories.
I have some scratches left from bad wiper blades.
But I'd buy new glass before spending $1500, or even $500.
