My Challenger is too loud!
surfnturf
Woodside, California
I'm, very familiar with the saying "if it's too loud.... you're too old". At 64, I guess I'm too old. The previous owner swapped out the stock mufflers for some aftermarket flowmasters. It's not horrible, but definitely louder than I like. Do any of you have an opinion on the stock mufflers? The previous owner gave me the originals, which look like new. He complained that it was too quiet and felt that it compromised the performance. I find that hard to believe. I'm seriously considering having the original re-installed but thought it would be worth hearing other's opinions. Also, the current quad tips are sitting just shy of flush from the rear valance. Is there a target distance that they should be sitting proud?
I can't speak to your question directly, but I will tell you that on my last build - 55 chevy - I bought some mufflers everyone said would be great and not too loud. I ran them for a bit and felt they were definitely too loud (I'm 63 BTW).
So after some (more ) research I picked some different mufflers and did the work to swap them out. I am happy with the results and it made me realize the sound is very subjective and what one person thinks is fine, another considers loud and vice-versa.
I'm building a 70 challenger convertible now with a 392 hemi, so I will be looking for the right set of mufflers for it. Definitely won't be stock, but not "too loud" either LOL.
I seem to recall someone said exhaust tips need to be 1/2"-5/8" out.
Any more than that look gaudy, Any less the valiance and bumper get "soot" covered.
Very helpful! Thanks!!
The older get. After driving one of my classic cars all day. Sometimes I think about making them quieter. Sometimes, I said. I actually haven't gotten that old yet. However, everyone knows when I am coming in my blue Challenger.
Roby a shipmate. He explained it to me by taking me for a ride in his 69 383 4spd Road runner. It didn't have a stock exhaust. So I opted to keep the stock exhaust on my challenger. The owner before my said he had the muffler burned out. I did get stopped for a load exhaust a few time in Philly. They would look and it was all there!
An exhaust resonator reduces unwanted engine noise by modulating sound frequencies, helping to create a smoother and more pleasant exhaust note. It works alongside the muffler to minimize loud or annoying sounds from the vehicle's exhaust system.
What is an Exhaust Resonator?​
An exhaust resonator reduces low-frequency droning noise from the engine. As cylinders fire to produce power, pressure pulses travel through the exhaust pipes. The pulses contain a broad spectrum of sound wavelengths. Without any dampening, the frequencies around 30-60hz are most noticeable as bothersome, sustained droning.
• Resonators are not designed for noise reduction— They’re designed for sound quality improvement.
• Frequency targeting— They focus on eliminating specific, often high-pitched frequencies.
• Minimal impact on performance— Resonators generally don’t impart a significant exhaust backpressure.
• Position in the system— They’re typically located between the catalytic converter and the muffler.
As sound waves pass through the resonator, some are absorbed while mid- and higher frequencies transmit onward. This attenuates the most offensive resonances without completely silencing the exhaust note.
It’s mostly a hollow tube with a few baffles that cause it to act like “echo chamber” where the exhaust noise bounces off the sides, colliding with one another and cancelling out the highest pitched sound frequencies.
When I bought my car, it had a fairly new aluminized reproduction stock system, that is resonators under the rear seat area, and mufflers beside the gas tank. I always thought they were the other way around due to the shape, but this is correct. The resonators are the oval shaped ones, the mufflers are round. I have a stock 383. I always thought the car was extremely quiet, too quiet. Did not sound like the Mopars I was used to hearing. Anyway, I had a need to mess with the fuel sending unit, and the welded muffler on the drivers side was in the way. I cut both mufflers off, and after gas tank issues sorted out, had a straight section of pipe replacing the mufflers. Now have only resonators. Sounds much better, and not too loud.
I had mufflers on my 440 Charger that were similar to the old thrush hush... and they were too loud. I removed them and went with what was then the sonic turbo's. Nice and quiet, and best of all I could actually hear my engine sing when the secondaries opened! I just really don't like not being able to carry on a conversation in the car because of the noise. Very unpleasant no matter how old I am!
I run 2.5" x-pipe with Aerochamber not to loud if you look at the Vanishing point highlights there is a good shot of the rear with the tips should give you an idea
