SOLD original 1970 Cuda' 340 4 speed
lift2win
SOLD!!!!!!!!
Original 1970 Plymouth Cuda’ 340 4 speed
This Cuda’ has all matching body numbers and door jamb vin sticker however original motor and trans are long gone.
A complete rotisserie restoration. The car was completely stripped, media blasted and coated with dp40 primer. Any rusted panels were replaced with either OEM or AMD sheet metal, no cheap metal used. After sheet metal car was primed with PPG primer and blocked straight. Lemon twist (original color) PPG base coat/clear coat. The under carriage interior and exterior was all painted for a clean look. Every part removed including suspension was removed media blasted dp40 primed and painted with ppg paint. Car has original restored 15X7 rallye wheels
Car originally had a twin scoop hood now has a shaker
Original 8.75 rear end with 3.91 sure grip
Engine, trans, and rear end were all rebuilt.
Engine:
· 400 block completely rebuilt
· Eagle 512 stroker kit
· Full roller cam/rockers
· Massaged eddy aluminum heads
· ½” oil pick up
· All ARP hardware
· Custom quick fuel carb
Whats new:
· Forward light, engine, trans, and tail light wiring harnesses
· Door sills
· Kick panels
· Dash pad (not a cover)
· Headliner
· Carpet
· Seat covers and foam
· Interior hardware
· Package tray board
· Seat divider board
· Door handels
· Window cranks
· Door locks
· Exterior door handles
· Entire braking system
· Clutch
· Entire drivetrain (minus original rebuilt rear end)
· All new seals
· All under hood electronics
· Fuel lines, tank, straps and sending unit
· All new hardware
· Gorgeous paint
· All front end bushings and steering linkage
· All 4 shocks
· Leaf springs
· White letter tires
· Many many other things, over 35k spent on just parts for this resto
Car still needs a few minor things to be 100% which I will be working on until this is sold. Listing it cheap because of this, things missing are 4 speed console plate, corner rear window trim piece, very few other small odds.
Asking $37,000 OBO
Please call, text or email for pictures or more information
I am located in northern IL about 40 miles west of Chicago
DetMatt1
Metro Detroit
I'm not your buyer but the car sounds beautiful. Pics would benefit your effort for sure!
