Nov 5, 2025 #1 K Kevineng Active Member Joined May 6, 2024 Messages 39 Reaction score 42 Location Minnesota I have a 72 challenger, the original shaft is 1 1/8" Can I install a steering box from a 73 with a 1 1/4" shaft? Are the pitman arms different between the two? (obviously other than the diameter)
Nov 5, 2025 #2 Challenger RTA Well-Known Member Joined Oct 28, 2018 Messages 5,059 Reaction score 2,874 Location PA Flood city Kevineng said: I have a 72 challenger, the original shaft is 1 1/8" Can I install a steering box from a 73 with a 1 1/4" shaft? Click to expand... Yes. Are the pitman arms different between the two? (obviously other than the diameter) Correct. You are referring to the pitman arm.
Nov 5, 2025 #3 heminut Well-Known Member Joined Dec 28, 2008 Messages 954 Reaction score 808 Location Deming, New Mexico The boxes are interchangeable as long as you have the correct pitman arm to go with it.
Nov 5, 2025 #4 K Kevineng Active Member Joined May 6, 2024 Messages 39 Reaction score 42 Location Minnesota Ok, thanks.
