AlleyoopMgv
I currently use Iwata LVX "Extreme Basecoat" 400 with a 1.3 tip for basecoat, and a Iwata LPH 400 with a 1.3 tip for clear. These are $500-$600 spray guns, but it's how I make my living.
In the past, I've used SATA, DeVillbiss, Sharpe, Accuspray, and the list goes on........
But anyway's, you don't need to buy a $500 gun in my opinion, but I wouldn't recommend a $150 gun either. The cheaper gun's have there purpose. I would suggest a middle of the road kinda gun that costs around $300 or so.
Something like this vvvvvvvvvvvvv
Here is the link also: http://www.tcpglobal.com/spraygundepot/itemdetail.aspx?itemno=DEV+GTI-620G
170156 GTI MILL. HVLP GRAVITY GUN/CUP (#2000-1.3,1.4,1.5) ~ Item Number: DEV GTI-620G
List Price: 548.90
Your Price: 329.99 (EA)
Total On Hand: 157 (EA)
Qty
Email to Friend
• The Ultimate HVLP Base Coat/Clearcoat Gun
• Excellent value because this gun is basically three guns in one
• GTi® Gravity Gun Includes: 1.3 mm, 1.4 mm, and 1.5 mm fluid tips
• 1-Liter aluminum cup with push on lid
• High output air adjusting valve with gauge
Excellent value Three guns in one GTi® Gravity Gun Includes: 1.3 mm, 1.4 mm, and 1.5 mm fluid tips 1-Liter aluminum cup with push on lid High output air adjusting valve with gauge Spray lube, fluid filter, gun hook Key Features: Advanced technology for the professional painter 25% larger spray pattern-for fast coverage Even distribution of metallic for no mottling or striping Excellent color matching capabilities Optimum atomization for clearcoats and single stages produces a high gloss finish and minimizes orange peel. Excellent fluid control for applying more film build with fewer passes Lightweight and comfortable Highly efficient HVLP design Waterborne compatible--stainless steel fluid tip and needle, electro less nickel-plated gun body inside and out Less time spent on refills--32 oz aluminum cup with disposable push-on lid. Wide cup opening for easy cleaning
List Price: 548.90
Qty
Email to Friend
