Rear Disc Brake Remorse
rklein71
Amarillo Texas
Is anyone out there having rear disc brake conversion remorse. The Cadillac Eldorado calipers are a major pain in the butt. The bleeders are not located on the top, the adjustment for the parking brake is very difficult. Kind of wished I had stayed with rear drums.
I, too, have heard more stories of regret than joy putting rear disc on the e-body (and b-body)
four disc, all-around, seems cool and modern. but in terms of braking force, it isn't warranted. Unless you're towing a boat, or something. ;)
Yep I have done it, never again unless I'm building a 200mph car, drums are fine for the rear in any application I plan on using. I did a willwood set, $$$ they worked fine but for the money, not really worth it.
Knowing that the rear brakes don't do near as much as the front brakes, I never considered going to the expense of swapping. I did source the parts to go to the bigger 11" drum brakes from the salvage yard and upgraded to the bigger drum brakes. I also put in an adjustable proportioning valve.
