rear mufflers.
michael bucklew
both muffler pipes are up against the "rubber" hanger. on the left side the pipe is against the brake line backer going to the rear brakes. do i need to shorten the pipe coming out of the muffler bought from an E-body muffler specialist
moparlee
Mid Michigan
If everything else is in the correct location, I would be talking to the supplier and tell him the cross over pipe in not right.
michael bucklew
i am using the round mufflers that go under the trunk. big bend over axel. ----maybe let muffler shop solve problem
ph23vo
seattle
YOU JUST DO NOT HAVE THEM INSTALLED CORRECTLY...I SPENT 4 HOURS DOING MY TAILS AND MUFFLERS..[ALL FROM THE GUY IN OREGON...] AND I FINALLY GOT THEM PERFECT...GOOD LUCK ITS DOABLE
