removal of tripometer dial: rallye cluster
Huskidrive
If you are talking about the chrome plastic reset knob there is a small screw inside. Use an eyeglass screwdriver to remove it. It's very small and easily lost!
djais1801
Sand Box
thx Husky...i'm assuming it's on the back side?
Not Jonathan
72-74 is pressure fit, wiggle gently to take off. I'm pretty sure 70-71 has a tiny set screw that goes down the center of the knob from the front.
ctaarman
If your's has the barrel set screw, it is removable with jeweler's screw driver. Loosen it, then carefully pull the knob out and the barrel set screw will fall out the front when you tip it. Be very careful to put a sheet or something else underneath it, because if you lose it to my knowledge no one sells just the set screw anymore. Mopar parts guys will gouge you $40 for two knobs and two set screws (the second one is for the clock).
