Replacing starter
70challengerRT/SE
Mishawaka,IN
In process of replacing the starter on my challenger. I have the starter loose. What all needs to b removed to get that starter outta there? Don't want to take off more than I need to. Thanks
roadrunnerman
n.e.iowa
i assume you disconnected the battery cable.Just undue the relay wires from the starter drive,Then as long as you got the bolts removed from the starter/tranny it should just slide out, you might have to twist and turn the starter at an angle and work it between the block and exhaust,but that's about all there is to take it out.
