Steering column adapter?
tazzymoto
I'm using an original ebody steering column and need to adapt to a double d universal. Does anyone make a splined adapter to fit the stock shaft?
I don't know about a splined adapter, but the Reilly Alterktion setup includes an adapter to go from the stock shaft to a double d universal. When you remove the original coupler, you put a shoulder bolt where the original press pin was in the shaft. I suspect he is getting it from Flaming River, but I don't know if he has to drill the bolt hole in it or not. You may be able to order one through him.
