Tail Panel Trim on a ‘70 Cuda
Fishgutz
Northern California
Looking for advice, instructions, photos, videos or any other info about installing the tail panel trim on a ‘70 Cuda. Tricks of the trade or any help will be greatly appreciated. Many thanks in advance.
Fishgutz
Fishgutz
Northern California
Thanks rklein 71,
That’s looks super helpful, really good advice. Looks like we’re going to get busy the next few evenings with the install. Photos to follow.
rklein71
Amarillo Texas
I installed Cuda tail panel trim on my BHG last summer. Looks great!
mmissile
Macomb County Michigan
After restoring the body...I left mine off my 70 ragtop. I deleted some chrome from the car. I like the black-to-color look.
Fishgutz
Northern California
Hi mmissle,
I thought about that also, mine is the original tail panel and has holes for the clips. It was really an after thought, but I do like the trim on it, gives it a nice contrast between the black and purple. Thanks for the input......
Happy Hot Rodding
Fishgutz
Northern California
We unpacked the new trim and fastener kit. First thing we noticed the plastic keepers have a stud too long to allow the trim to slide over it. Is it a cut to fit situation? Or am I missing something?
rklein71
Amarillo Texas
I believe the one end (not the splayed end) breaks off. That cylinder is used to insert into the splayed end to force it apart and keep the clip in the hole. I didn't use them, I found some roofing nails and cut them down to size and pushed them into the splayed end instead. I found the little plastic cylinders really hard to work with.
moparlee
Mid Michigan
I have used those plastic clips before for installing trim. Take the cylinder out, push the splayed side into the panel, then push the cylinder in until it is flush with the flat piece of plastic.
Fishgutz
Northern California
Perfect, thanks guys. I knew there was a trick to it, we’ll give it a try this evening. I’ll post a photo when successful with the install.
