Using a 1970 Challenger tail light panel to restore a 71 tail light panel
asskicked
Hello All
Finally running out of body metal work needed for my 71 Challenger, the tail light panel is next.
My original looks OK but it has too much filler in it to look OK.
I've heard of guys using the 70 panel to repair the 71 but can't find anything with photos.
Since I will be cutting up a repro to do this, is there any reason why I should use an expensive AMD part over the cheaper Sherman part?
Any input appreciated, Thanks!!
Go with the cheaper Sherman part since you chopping it up anyway. The AMD part would likely fit better in the 70, but that's not what you're after.
