Which rear axle is correct?
STXCuda
I am currently building up my 1970 Barracuda, it will be a Hemi clone car with Automatic. What rear axle is correct for the car the 8-3/4 or the Dana 60? Also side note were automatic hemi cudas available with column shift or are they all console shift cars? thanks!!
MoparCarGuy
1970 HemiCudas with the D32/D34 - 727 Torqueflite Automatic transmission could have either an 8-3/4" rear axle (3.23 or 3.55 gears) OR a 9-3/4" Dana 60 axle (4.10 gear only).
The base axle was the 8-3/4" with the 3.23 gear and no A3# option code on the Fender Tag or Broadcast Sheet.
The 8-3/4" axle could be upgraded with option code A36 - Performance Axle Package to get the 3.55 rear gears and Sure Grip.
A36 - Performance Axle Package = 3.55 Ratio in a 8 3/4 Axle w/ Sure Grip, 7 Blade Torque Drive Fan, 26″ Radiator w/ Shroud and Hemi Suspenson Handling Package. Only Available in 340 & 383 4 barrel w/ either Trans or 440 & 426 Hemi w/ Auto Trans.
The 9-3/4" Dana 60 was also available with the Automatic Transmission if option code A32 - Super Performance Axle Package was ordered.
A32 = Super Performance Axle Package = 4.10 Ratio in a 9 3/4 Dana Axle w/ Sure Grip, 7 Blade Torque Drive Fan, 26″ Radiator w/ Shroud, Hemi Suspenson Handling Package and Power Front Disc Brakes. Only Available in 440 & 426 Hemi w/ Auto Trans.
The Dana 60 with 3.54 rear gear (option code A33 - Track Pak Package; 4-Speed Only) was not available on the 727 Automatic Transmission cars.
Column-shift info:
1970 Barracudas/Cudas ordered with a V8 and an automatic transmission but no console received the column shift even on a HemiCuda.
Example of a 1970 HemiCuda with column-shift automatic and A32 - Dana 60 with 4.10 gears.
If you ordered the C16 Console, you got the Slap-Stik floor shifter.
It has more to do with traction , the tires prevent damage But if the tires cannot spin & the front tires lift torque will break them
MoparCarGuy
Yep, high torque and traction (slicks) do not bode well for the 8-3/4’s longevity.
I guess in this case it depends on what is planned for the car.
Racing? Upgrade axles or go to a Dana 60.
I had a 71 Duster 440 4 spd , It was caged had floating ladderbar suspension , on the street I ran dirt track compound DOT tires , at the track 11x 29 slicks , it would lift th front tires for about 40' ran 1.4 to 60' . It twisted the axles on the first pass at the track , I chose to by new axles rather than build the dana . It also lifted the front tires on the street , I would replace the center section on the 8 3/4 roughly yearly , should have built the Dana from the start .
STXCuda
Column-shift info:
Exactly the type of information I was looking for! Thanks for the great example as well.
