Latest activity
  • Katfish
    Seems pretty obvious there are at least 2 different shapes, so they can't all be E-body. Looks like some have the slanted edge I'd...
  • M
    Or when all the hood supports are rusted slap through? :D
  • M
    moparmandan reacted to JDMopar's post in the thread SOLD Two very rusty Barracuda's with
    Like
    Like
    We should start a pool on how long it will take the blue one to break in half when somebody starts winching it up onto a trailer! :oops:
  • Xcudame
    Xcudame replied to the thread INFO needed Keith Black Hemi.
    I think you could run a set of metal o-rings and a msl head gasket and be fine. I'm pinging @Chryco Psycho as he has tons of knowledge.
  • Xcudame
    Xcudame reacted to heminut's post in the thread INFO needed Keith Black Hemi with
    Like
    Like
    That block and the heads shown are cut for wire Orings, a common mod for drag race engines back then. They ran solid copper head gaskets...
  • F
    Fordication reacted to pschlosser's post in the thread Engine idle not working with
    Like
    Like
    the ballast resistor can break. it becomes brittle over time, and not an uncommon thing to fail at least once in 50 years. the ones...
  • heminut
    heminut replied to the thread INFO needed Keith Black Hemi.
  • pschlosser
    pschlosser replied to the thread Engine idle not working.
  • pschlosser
    the condenser is kind of optional. mostly to suppress ignition noise on the AM radio. If you suspect its faulty, just disconnect it...
  • F
    Fordication replied to the thread Engine idle not working.
    Just checked it. 1.7 ohms and 12.8 oms and the 12.8 ohms is bouncing all over the place. Will not settle down. Bad resistor. I am...
  • Xcudame
    Almost all of the pictures of the bores show notches. I highlighted one so you know. Hopefully some of the Hemi guys will chime in...
  • heminut
    heminut reacted to Snowdog's post in the thread Old Superbird Pics with
    Like
    Like
    Here's some old Superbird pics from the 80's or 90's era. They had several superbird owners run their cars around the track at MIS...
  • F
    So I think you put me in the right location. Will let you know in a minute if the resistor is bad.
  • F
    No. I know where the ballast resistor is and the ignition coil condenser. After doing some research it would appear that both of those...
  • Cuda Hunter
    Cuda Hunter replied to the thread INFO needed Keith Black Hemi.
    I ask about the 413 because I have several industrial motors as well as a few 6 bolt motors. The bore is 4.25. The owner ran this...
