flasher relay
djais1801
Sand Box
Where is the flasher relay located under the dash? The FSM says its on the brake pedal bracket....I don't have one on the bracket. Can someone send me a pic?
Rapidfire
Culbertson Nebraska
This should get you close!
Rich G.
4 way flasher is on the fuse block and the directional flasher is usually behind the ash tray
Rich G.
The one in the fuse box. They are both the same part but 2 separate functions
Here is where the two flashers are located. Circled in red on the brake/clutch support and on the side of the ash tray.
Rich G.
I guess depending on what year you’re working on. Good picture. I believe the one on the pedal bracket if the 4 ways. Just checked my car, the flasher is not on the fuse panel like I thought. My bad, must have been my other car I was thinking of. Oops
