How to tell the difference between a 318 and 340
David B
Alaska & Florida
I bought my 1970 Barracuda used. the fender tag said it came with a 318 but the air cleaner cover says 340 four barrel. How can I tell the difference? I'm having the engine pulled for overhaul so access to the block # should be easy.
340challconvert
Parsippany, NJ
These may also help;
How to ID a Small Block Engine Block:
LA - Chrysler small block V8 engines
340challconvert
Parsippany, NJ
David, look for a number on the driver's side of the block, front, right below the head. A 70 engine would start with F.
A 71 engine would start with G. The next letter is where the engine was assembled, followed by the cubic inches engine size.
Check out the link I posted above; it has actual pictures of number ID locations
"How to ID a small block engine block"
It will give you all the information you need with photo locations
volunteer
Kamloops, B.C.
It's cast into the right hand side of the block in my experience
It's cast into the Left-hand side of the block - large numbers - basically behind the starter. You can read it with a good light and a mirror, as necessary. Either 273, 318, 340 or 360 will be displayed - then a dash (-) and single number.
ie: The 340 casting number will be 2780930-340-3.
Hemivision
Sounds good to me.. just a slip...
Edward Hackett
Edward Hackett
The last two photos are the casting date, and even what shift cast it at the plant.
