robert power
- Joined
- Feb 15, 2016
- Messages
- 172
- Reaction score
- 84
feels normal about 2 to 3 inches
yep, mine the is same way with factory stuff. Push rod adjustment maybe??? Or smaller bore for more pressure???feels normal about 2 to 3 inches
Good job BSG! Lock em when you get chance.That appears to have taken care of it. Feels good like it actually has power brakes. Its raining here and its never been out in the rain since it came off the rotisserie. Its obvious the hard pedal with the worst brakes Ive ever had problem is gone.To be honest, it was embarrassing even blogging about with the amount of wrenching exp I've got. So the fix for me was taking the keyboard away from the guy at the local kragen and I found a power frt disk with rear drum on a 69 challenger with 1 inch bore part# BHH 10-1326. 33.00$
I'm not a date code guy just like form and function above all else. The replacement was shorter and definitely had a smaller bore than the one taken off.
Hope this info helps you out!
I found success with a manual system with a Dr Diff 15/16” aluminum master, factory disc brake combination valve that was used after 1-1-1970 and the factory metering valve. Solid good pedal with a slightly longer pedal travel. My car stops without issues. Rotors are 11.75” and rear drums are 11 x 2.5”.bump.....well what is the outcome of the smaller MC? Have a 1970 Barracuda. Went from drum/drum to disc drum like many of you.
I have a similar problem. Before I tear into my system, I would love to get some more results please.
Thanks in advance.
Dennis
FWIW I used all Mopar brake parts and can lock all 4 wheels. I put a pressure gauge on the front calipers and get 1200psi. It’s enough to lock them.I have now replaced a problematic MS and the car stops without the BRAKE light on the dash coming on. Still, I can't lock
my brakes up. The system is better , but I would love for it to stop and give me nine cents change from a dime![]()
