buckle cover removal how to?
70rag
Eugene Oregon
Anyone know how to remove the cover of the buckle....don't want to break it...
70rag
Eugene Oregon
how did you remove it?
The metal has very small embossed protrusions that the plastic snaps over. Use a thin knife or feeler gauge or similar, between the plastic and the metal. It doesn't take much pressure it pops off easily.
Tactical185
Great info, thank you. My girls and I took the convert for a cruise. After buckling up, my little girl said “daddy this broke”. The black plastic cover broke in half. Did you have to replace yours and if so, did you find a replacement??
thank you
70rag
Eugene Oregon
mine did not break, however one is cracked and I will attempt glue/epoxy or what seems appropriate at the time...lol
68bee
Huntington, NY
Those are ABS plastic you can fix them by using MEK from any hardware store.
Dip a q- tip in the MEK and wet the broken edges and then press them together.
Hold for about a minute and it should be good.
You have to do this fast once you wet the edges, They should not dry.
I wait a day before putting it back together.
Tactical185
thank you, I will give it a shot on my seat belt. Do you think it will also work on this plastic convert clip ??
68bee
Huntington, NY
I don't know what type of plastic that clip is. Dip a Q-tip in the MEK and dab it on the plastic clip. If it softens the plastic it should work.
