Hello!
I am trying to replace the downflow (genuine?) Radiator that has been installed so far because it has cracked.
We are planning to be cool 63177 (Crossflow, Overall Width (in): 33.000 in.Overall Height (in): 19.000 in.Overall Thickness (in): 3.000 in.)
The question here is that if you search for 70 challengers, small block categories, and becool brands in summit, you will see several radiators, and I chose the largest radiator. Will the cooling capacity increase if the area is large? ??
Also, when changing from downflow to crossflow, do I need to change to a high flow water pump?
The position of the cooler of the transformer has changed and the handling of the pipe has also changed. Is there a dedicated fitting or hose?
(I did not find the image I was wearing when I searched.)
Or is it more efficient to install a separate oil cooler instead of the radiator transformer cooler?
I have a question about cooling and transformers, is it okay for the cooling forums?
thank you for reading it until the very end!
