Yes I meant the interior door panelsI would restore the doors. I usually pull the door if there's a lot of work and gut it. The hardest ones to get push out are behind the impact bars! I use a slide hammer after I spot weld a nail to the dent in those areas, the rest you can massage out with a body dolly and small hammer. Just get them out as close to orginal as possible. I usually use lead on the doors smooth out a real small area but a small amount of good bondo is easier to do.
ThanksShould of looked closer! My Bad! Anyway, yes I did restore my inside door panels and repainted them and that's just exactly what they look like. Lol. I would just buy some good quality new ones and save a lot of time and be done with it! IMO
ThanksI used Herb's Parts interior paint to redo mine. I lightly sanded a couple deep scratches before hitting the panels with a few light coats of the spray-on dye. I was very happy with the color being refteshed from how faded they were. I guess it depends on your goal. For me, making them look better, although not like new, was fine. And after a few months it is still holding up well. No chips or flaking at all.
Thank YouYou might find this interesting too! Page 1 and page 5 show the before and after on the following restoration of panels.
Interior Plastic Restoration Journey in Interior
Terry
Yes, ThanksIf you paint/'dye them, make sure to use the plastic primer adhesion products under the paint. They make a huge difference in how long the paint wants to stay on the plastic.
Fix the ones you have and look for a perfect set in the meantime.
