Fordication
Hello. I am looking at buying a 74 Challenger locally. The car is pretty much disassembled but the body and the wheels to keep it off the ground. 95% of the parts are there and there is no rust on the car. The Engine is not original but is a 383. Someone pretty much sprayed the car with POR 15 to prevent corrosion. I checked and there is very little bondo except where someone removed the vinyl roof and filled in that welded area. I am sure about the corrosion as I had the car off of the ground and used a magnet on ever square inch of the car. There are no door panels and its an RT car based on the fender tags, the VIN and whats on the car. It is also an AC car which is desired where I live. The guy is asking 12500 and I do not see how I can pass up this deal. Does it sound like a good deal to you guys. No, it has not been wrecked and all fenders appear to be original as do the doors and the quarters. Thanks
