FOR SALE Fuel filler tubes
DetMatt1
$15 each for the Barracuda and $25 each for the Challenger + shipping from the Detroit area.
‘I’m not sure what the straight one belongs to yet so if you have can ID it for me that would be great.
The vapor separator in the pic will be in another ad.
What is the shape of the best challenger tube? Same with cuda?
I’d call them all decent and useable with surface rust on some. if you look closely you’ll see that one of the challengers tubes has a nipple near the top while the other doesn’t.
I have been told that the tube without the nipple is correct for a 9/69 challenger.
Anyone else confirm this? Looks like that's the one I'm interested in.
cuda hunter I believe that on your fender tag you would need to have a N95
(evaporative emission control).
Your trunk on the right side would have a vapor separator. if your car didn’t have a fender tag I put the non-emission gas tank in,with the vent lines going to the frame.
Anybody have thoughts on what the vapor separator tube is worth? I’ve only found one comp and they’re asking $375 which I think is absolutely ridiculous.
Sorry, no thoughts on that rarer Challenger tube, but I have a question.
Do all your Cuda filler tubes have the dent/depression on the top side?
For some reason I always thought the "dent" was a '70 only thing and '71+ had that obstruction at the bottom of the tube. All the reproductions are the "dent" style. Thanks.
I have 2 with no dents and obstruction at bottom and 2 with dents and no obstruction and one that had the dent that somebody somehow hammered the dent flat…:realcrazy:
Thanks, confirms my assumptions.
1970 only - with dent, no lower obstruction.
1971 and up - no dent, with lower obstruction.
If I'm wrong, or if anyone can shed more light on this I'd like hear from you.
It would seem the Cuda reproduction filler tubes are like the Cuda rallye hood scoop insert reproductions. They're both made in the 1970 only style.
Sorry if this post is considered a high jack.
John
John
Not at all, good info is good info!
yes that is correct. N95 code has no nipple
L A Built car. do you have a build sheet for that car?
I think the tag say 9/23
Cuda Hunter
Sir that’s one awesome car. It is a federal car does not need that emission tube. You are a very lucky man. N85 is a tach which is a rallye dash Assy. If you need a picture of the vent tube let me know I can shoot for a picture.
Cuda Hunter
Federal?
