Looking for AC reference pics
fishpwr
Iowa
I have a 71 Cuda, 383, with AC. When I got the car the engine was out and completely disassembled. I’d appreciate some reference pictures of the engine Bay Area (AC lines, AC condenser supports, pulleys, brackets, the heater control valve, anything would be appreciated). Wanting to put the car back to its original state. Many thanks!
DetMatt1
I took some reference pics before pulling the engine for rebuild. Original N code with ac. In hindsight I should have taken more…
DetMatt1
I didn’t reinstall any of the underhood ac components but of course I kept everything an I’m seriously considering having it redone and putting it back Soon.
DetMatt1
I saved these a few years back as additional reference. Also a ‘71 N code.
cuda joe
nj
I have a 71 383 with ac i hope these help
cuda joe
nj
the eccentric bolt and washer for the upper control arm ? visable in the pic of the whole engine bay
michael bucklew
michael bucklew
routing for big block and small block A/C are the same. most parts can be found at NAPA---new hoses can be rebuilt at Vintage Air in Tampa Flordia
knahavasu
Lake Havasu City
What is the round thing on the pass. fender well just behind the horns?
It is the Dryer… replace it. If you are converting to R 134 you need to get the lines rebuilt, rubber hose and charging ports changed. Check out original air. They redid mine. Lot of good info on their web site
sdcbowler
Wondering if anyone could answer a question for me. I have a '70 Challenger, original a/c. My question is concerning the a/c compressor. I also have a small 8 gallon air compressor that requires oil. Can I use the same oil I use in my 8 gallon air compressor in my a/c compressor?
Thanks much
cuda joe
nj
you need ac oil what kind depends on the type of refridgent you use go with what is recommended with the refridgent.. flush all lines; evaperator;condenser replace drier..replace o rings. they sell a ac flush it gets old oil and contaments out
sdcbowler
Thanks Cuda Joe,
I'm not referring to the refrigerant that flows through the lines and the system. I know that requires R-12. I am talking about the oil inside the compressor body where the two pistons and the rods are located for the purpose of lubrication.
sdcbowler
OK. I will be using the original R-12 refrigerant. Do you know where I can get a flush kit from?
