Lots of good info so far in this thread. I also run a stroker 440 (500CID). I think the telling item you mentioned is that it runs find for 30 minutes then you have a problem. I am suspecting you could have debris in your fuel tank that is collecting on your fuel sending unit "sock" and restricting flow. The debris collects on the sock and then falls back off when you turn off the engine.
You will need to check a few things to figure out if this is your issue. Pulling the fuel tank sending unit is no fun so start by visually inspecting the entire fuel line including any rubber hoses from the tank sending unit connection up to the carburetor. You want to rule out collapsed rubber lines, possible fuel line damage (crimping), an unknown fuel filter that is clogged, etc.
If all looks okay, consider removing the fuel line at the carb and putting it into a good-sized bucket. Turn on your electric fuel pump and see what happens for fuel flow into the bucket.
If you do not get good flow, you have a restriction somewhere from the tank to the carb
OR a problem with the electric pump and/or mechanical pump. You may want to bypass the mechanical pump altogether and see if your problem goes away. The electric pump should be pressurizing your entire fuel line and that makes fuel percolation (vapor-lock) less of a problem. The mechanical pump, as noted by
@Chryco Psycho, is not really doing much for you and may be contributing to a possible vapor-lock situation. Plus, it is a safety issue using both pumps. I do not recommend running an electric pump and a mechanical pump together as a failed mechanical pump diaphragm can lead to the electric pump filling your crankcase with gasoline. Very BAD. If you do abandon the mechanical pump, remove it and the fuel pump pushrod and install a block-off plate.
Good flow, then it tapers off? You have a restriction somewhere and it could be that fuel tank sending unit sock.
Good flow and it appears to stay good? Install a fuel pressure gauge to see what you get near the carb. 5 to 7 psi is all a carb needs but pressure does not prove flow capacity. The potential for vapor lock is still there even with an electric fuel pump.
And, last but not least, you may have to pull that fuel tank sending unit out to check the sock and look into the tank for debris. An upgrade of your entire fuel system to 3/8" is highly recommended. The factory 5/16" fuel tank sending unit and fuel line is marginal for the engine's needs. Hard tubing is measured as Outside Diameter (O.D.) so you have <5/16" internal diameter (I.D.) now. Fuel line hose is measured in I.D. so 5/16" hose is really 5/16". For your stroker motor, 3/8" fuel line tubing is minimum. A good option is to repurpose your existing 5/16" fuel line as a return line and purchase a new 3/8" fuel line for your supply line. This will keep fuel flowing which is easier on your electric pump and can prevent vapor lock since the fuel does not remain in the line to "boil".
Let us know what you find and good luck troubleshooting.
