Gilmer Pulleys
Ricky J
Hi i have a 358 R5P7 twin turbo engine and has a stage 3 dry sump set up.The dry sump pump has a gilmer pulley and belt .Water pump is on its own Vbelt pulley set up.And alternator is on its own Vbelt offset from water pump.
What i would like to know is there a Gilmer pulley and belt set up with idler pulleys that i can run all 3 .
Thanks in advance
Steve340
New Zealand
You are better off to leave the oil system alone IMO. Plus the oil pump takes a fair bit to drive it - no point risking a loss of oil pressure.
Ricky J
I was going to leave the oil system on the gilmer belt it is on now but want to upgrade the alternator & water pump system to gilmer belt to stop belt slippage .
Steve340
New Zealand
To clarify : IMO do not try and run all 3 from the same belt.
I have never seen a system like you are asking about but they could exist.
heminut
Deming, New Mexico
If you're experiencing belt slippage on your waterpump and alternator (don't know how you could even tell) with a V belt then you probably need to adjust the tension.
