Organisol Paint
KennyCuda
I want to re -paint the hood on my TA what's the best paint to use with the texture to get the best results ?
Join E-bodies.org if you are not already a member. Lots of good tech info there.
I was told Mike Ross at BE&A has it right. I called him a couple weeks ago and he gave me this recipe mix for that Black Argent finish. I’ve not had time to try it myself but planning soon for my AAR. This is the mix ratio per quart.
1. 1 Qt Hot-Rod black
2. Tablespoon of SL1999 ppg
3. Flake Ultra silver mini umf02 from House of colors 1/4 bottle
He said that will get it very close and to try that mix and adjust accordingly. Also he added that it would take approximately two quarts to do all of the black argent on the car, hood, top front fenders, grille, and tail panel. I plan to spray all of it at the same time to get it matched perfectly.
There is no flake in the mix . The 349 is a poly found in most mixes.I have to research that.The suede gives it the finsh and texture. 431 is a fine poly. 433 medium poly. 635 course poly. I need to reference the toner list when I find it. 300s are lacquer 400s are enamel.600sDBU.
I see, I’m open to try it, with what’s available these days to get it close. Thanks I’m following here…
I've seen Cody's work and it looks very original.
Its very hard to find and keep clean. If you do find it make sure you have the right size tip for your gun.
